Old 08-06-2015, 02:00 PM   #1
Default Can 1 Raspberry Pi 2 Run Two Arduino Mega using USB?
I am trying to run 2 Arduino Mega from two USB ports of my Raspberry Pi 2 and use it on my project. I am providing a 5V 3A continuous and 5A peak Regulated Supply to power up my Raspberry Pi 2. And I am using up all the raspberry pi 2 gpio pins and also all the arduino mega pins for sensor and other related things. So my question is does the raspberry pi 2 on this circumstances can power up both the arduino mega with all pins in use without any problem? Or I should made two seperate power supply for both the arduino mega and another one for the raspberry pi 2?
Old 08-07-2015, 01:05 PM   #2
That all depends on how much current the other components draw. The Pi has a poly fuse which trips at 2.2 Amps when powered through the USB connector. You need to workout the current of the other devices and also include what the Pi is drawing if you are using this connector.
How I can configure an AVR microcontroller PWM to find the set point using a servo (DC ) motor? tracert Microcontrollers (MCU) 1 06-04-2015 06:37 AM
Discussion: Read 10 or more switches using only two I/O pins of a microcontroller Radiolocman Robot Projects and Advices 1 03-17-2014 02:07 PM
Discussion: Connect a 43 matrix keyboard to a microcontroller using two I/O pins Radiolocman Robot Projects and Advices 1 12-23-2013 04:00 PM
Discussion: USB Audio Streamer A Microchip PIC based USB sound card Radiolocman Robot Microcontrollers (MCU) 2 01-01-2013 10:21 PM
Discussion: Add 512K of external SRAM to Arduino Mega. Part 3 - Software Radiolocman Robot Microcontrollers (MCU) 1 11-30-2011 02:53 PM
