Old 10-27-2013, 01:47 PM   #1
Default UART Atmega128 is not working
Hello. Cannot run the uart on the Atmega128. For a week now trying to solve this issue.
Maybe speed error or configuration bits?
The code of the program and the schematic are below.
Code:
.include "m1281def.inc"
.equ XTAL_CPU		= 8000000			; CPU (4MHz)
.equ baudrate 		= 9600
.equ bauddivider 	= XTAL_CPU/(16*baudrate)-1
.org 0
		ldi r16,low(ramend)  ;RAM
		out spl,r16
		ldi r16,high(ramend)
		out sph,r16
									;initialize device USART0
		ldi	r17,high(bauddivider)	;9600
		ldi	r16,low(bauddivider)
		sts	UBRR0L,r17				; baud rate UBRRL:UBRRH
		sts	UBRR0H,r16
		ldi	r16, 0b00011000			;ON RX/TX
		sts	UCSR0B,r16
		ldi	r16, 0b00000110			; async mode,parity off,1stop bit,8data
		sts	UCSR0C,r16
		ser	r18
		sts	UDR0,r18				;out UART
main:
	rjmp main
Old 10-29-2013, 08:27 AM   #2
You incorrectly initialize the UART0. And you chose the wrong *. inc file: instead m1281def.inc need m128def.inc.
Here is a sample code to initialize:
Code:
;UART0 init
      LDI R16, low(bauddivider)
      OUT UBRR0L,R16
      LDI R16, high(bauddivider)
      STS UBRR0H,R16
      LDI R16,0
      OUT UCSR0A, R16
      LDI R16, (1 << RXEN0)|(1 << TXEN0)|(0 << RXCIE0)|(0 << TXCIE0)
; Interrupts disabled, RX-TX enabled.
      OUT UCSR0B, R16
      LDI R16, (1 << UCSZ00)|(1 << UCSZ01)
; 8data
      STS UCSR0C, R16
And use the AVR Studio built-in simulator, there you step through the program clearly shows the change of the microcontroller registers.
Old 11-01-2013, 03:09 PM   #3
Thank you. You to help me. Now everything works.
Old 11-01-2013, 04:00 PM   #4
You're welcome. I was glad to help you...
Old 01-24-2016, 03:11 PM   #5
smartic
smartic is on a distinguished road
How to change the data rate?
smartic is offline   Reply With Quote
Old 01-25-2016, 09:13 AM   #6
change .equ baudrate
Discussion: Simple solenoid driver is adaptable and efficient Radiolocman Robot Projects and Advices 1 02-28-2013 08:55 AM
