Old 01-31-2016, 03:21 PM   #1
mark
mark is on a distinguished road
Default Platform to chose - Arduino/Raspberry Pi, or something else?
My company makes physical rehabilitation equipment based on various pendulums, fulcrums, levers that swing, push, rotate, etc.. To date the machines have been purely mechanical devices. We are now looking to add some intelligence to these machines, e.g:
- sensors (accelerometers, gyrometers, angular velocity, pressure sensors, bend sensors) to take reading about pendulum movements, repetitions, pressure on pads etc and other operational parameters, necessary to understand how machines operate
Each machine would have 1-3 sensors that we need to take the readings.
We then need to perform trigonometric calculations for torque, maximum velocity, etc. (probably on the processor on the machine or even in the cloud (?)
then..
- send the data (raw or processed) to the cloud server which will analyze the data
- receive feedback from the cloud server based on analysis of the data received from the machine
- have a touch screen to display:
a) the progression of the program (reppetition count, maybe a torque curve, etc) and combine it with b) data received from the server (e.g adjustments to the program)
it also need to:
- authenticate users on the system using something like a RFID band or maybe a fingerprint scanner
And possibly:
- have a camera for recording of exercise progression and stream the video to the cloud - not sure about that though...
What platform(s) or combinations would you recommend to use to manage the cost of the hardware in under few hundred dollars that can perform something like that?
Looking now at Arduino, Raspberry Pi, but unsure if these can do it best...
Many thanks for advise.
mark is offline   Reply With Quote
Old 02-01-2016, 06:39 PM   #2
Dear, arduino is a toy for children. May be PI more sutable, if you don't want to design your own h/w
Old 02-02-2016, 05:29 PM   #3
mark
What about Lemaker? Banana Pi?
Old 02-05-2016, 07:18 PM   #4
Ali_Ahmer
Ali_Ahmer is on a distinguished road
There are examples on the Web using image processing with the BeagleBone Black ( also dubbed "BBB" ), which is a core with an architecture few more powerful if compared to the Raspberry PI, but it costs almost 10$ more expensive.
Ali_Ahmer is offline   Reply With Quote
Using Arduino to high current 12volts inputs and output tracert Microcontrollers (MCU) 2 12-06-2015 06:09 PM
Software to control COM or Parallel port pin output tracert Microcontrollers (MCU) 1 08-16-2015 07:47 AM
Can 1 Raspberry Pi 2 Run Two Arduino Mega using USB? Anatoly Microcontrollers (MCU) 1 08-07-2015 01:05 PM
Discussion: Ardusumo: an Open Source Platform for Fighting Robots Radiolocman Robot Projects and Advices 2 12-23-2013 07:50 AM
Discussion: Add 512K of external SRAM to Arduino Mega. Part 3 - Software Radiolocman Robot Microcontrollers (MCU) 1 11-30-2011 02:53 PM
