Old 02-28-2016, 08:35 PM   #1
Em_13
Em_13 is on a distinguished road
Default Question about Crystal oscillator
Hi,I am a beginner in RF circuits , have a question about this circuit:What does the Freq-set variable Inductor exactly do?I built this circuit and output frequency is fix despite changing this Inductor. only audio volume in receiver is changing.
Does "oscillator frequency" mean output frequency or it is about FM deviation for voice?Thanks.
Em_13 is offline   Reply With Quote
Old 02-29-2016, 08:51 PM   #2
Oscillator frequency means the output frequency of the carrier but I cannot see how it is going to work. It is adding a small load on the crystal.
Old 03-04-2016, 10:02 AM   #3
Em_13
I want to use 33 Mhz crystal in 3rd overtone mode,Please help me to calculate the capacitor triplet for 99 mhz output.Is there any equation to calculate these capacitors?
Old 03-07-2016, 10:31 AM   #4
You should be able to analyze the circuit yourself. This is not a very complicated one. Look at the picture carefully and you will be able to make out features.
The 270R and 0.01uF are used for the emitter biasing. They can be left as it is. They are not part of the oscillator tank circuit. The emitter needs to be lifted up from the ground to get proper base bias.
Questions about UART communication tracert Microcontrollers (MCU) 1 12-06-2015 06:07 PM
Bootloading ATMEGA328P Question tracert Microcontrollers (MCU) 2 11-16-2014 05:30 PM
Discussion: Gnat-power sawtooth oscillator works on low supply voltages Radiolocman Robot Projects and Advices 1 08-25-2014 06:14 PM
Discussion: Crystal-oscillator circuit is ultralow power Radiolocman Robot Projects and Advices 1 12-27-2013 08:38 PM
Discussion: Low-distortion Audio-range Oscillator Radiolocman Robot Projects and Advices 1 02-12-2011 03:26 PM
