Old 04-01-2016, 05:00 PM   #1
DRN_231
DRN_231 is on a distinguished road
Default How to switch between 12/24 hour format RTC DS1307
I too is one who has found this difficult. But when I see this forum it looks like some one showing the color of milk to blind. Why not give the details from start to the end without giving so many problems, rather than trying to be smart and wise.
DRN_231 is offline   Reply With Quote
Old 04-03-2016, 11:30 AM   #2
brandonb916
brandonb916 is on a distinguished road
Well....If you have read DS1307 data sheet then you may get the idea how to set time. its simple, just go through the datasheet you will know.
brandonb916 is offline   Reply With Quote
Old 04-04-2016, 06:45 PM   #3
The DS1307 can be run in either 12-hour or 24-hour mode. Bit 6 of the hours register is defined as the 12-hour or 24-hour mode-select bit. When high, the 12-hour mode is selected. In the 12-hour mode, bit 5 is the AM/PM bit with logic high being PM.
110 to 12 volts reduction DRN_231 Beginners 1 10-16-2015 05:05 PM
How to record voice in mp3 format ? vhrdsao Beginners 1 10-11-2015 01:22 PM
How to connect a stepper motor to a bipolar driver Anatoly Projects and Advices 2 07-04-2015 05:04 PM
How do i connect a reed switch to a microprocessor? Jon Microcontrollers (MCU) 1 06-10-2015 02:37 PM
How to write data to the Eeprom segment ? Jon Microcontrollers (MCU) 3 05-27-2015 10:54 AM
