Old 04-04-2016, 06:46 PM   #1
wjoifeh
wjoifeh is on a distinguished road
Default 1-Wire thermometer not working in parasitic mode (DS9490R and DS18B20)
i have DS9490R USB dongle. It's USB to 1-Wire interface. I use it to run powered network of DS18B20 thermometers and it works as expected. However it does not work in parasitic power mode. (2 wires instead of 3).
Datasheet of DS18B20 tells me to connect both VCC and GND pins to ground wire of bus and DQ pin to data wire of bus. It should then get some power from the data pin instead of external power supply pin. You can find people on internet that succesfully use this setup. For me it's not working.
When i wire the probe in parasitic manner it just shorts whole bus and other chips disappear from it. I tried this with different thermometers from different vendors. I am also sure that i have wired it as is supposed. It does the same no matter if i connect the sensor directly into dongle or using my 1-Wire network (cca 15m of cables and splitters).
Do you have any idea why this should not work? Should i RMA the dongle?
wjoifeh is offline   Reply With Quote
Old 04-07-2016, 07:29 PM   #2
It is not correct to connect BOTH VCC and GND together. It is possible to get some power from the data pins.
Old 04-13-2016, 04:50 PM   #3
wjoifeh
It's in datasheet like that. It says: "VDD must be grounded for operation in parasite power mode."
Of course i didn't shorted VCC and GND of bus. I've shorted VCC and GND of sensor.
UART Atmega128 is not working Anatoly Microcontrollers (MCU) 5 01-25-2016 09:13 AM
TDA7052A and LM386 in low voltage power amp designs Cjuried Projects and Advices 3 01-21-2016 12:31 PM
Discussion: One wire brings power & data to LCD module Radiolocman Robot Projects and Advices 1 04-19-2015 06:12 PM
ATiny2313 and DS18B20 Anatoly Microcontrollers (MCU) 2 12-07-2013 05:13 PM
Discussion: Nokia 3310 Lcd Thermometer Using DS18B20 Radiolocman Robot Microcontrollers (MCU) 2 06-29-2011 08:15 PM
