Old 06-17-2016, 09:20 AM   #1
Em_13
Em_13 is on a distinguished road
Default ATmega128 error in fuse bits read
I am using USBasp to program my board with ATmega128, hardware is single side PCB by Thomas Fischl http://www.fischl.de/usbasp/
My board was working well and I decided to change some parts of the code but when I tried to read chip signature I got error (attachment) as well as when I tried to read fuse bits. I thought that maybe I have issue with CLK fuses and I applied external clock (5 V, 16.67 MHz) to the XTAL1 pin but without any success. I am confused because my board is still working as before but I cant make any change in program. Why I can not read fuse bits?
Em_13 is offline   Reply With Quote
Old 06-18-2016, 05:15 PM   #2
crazy-igzp
crazy-igzp is on a distinguished road
check:
* power supply
* reset
* uC clock frequency (in case you already selected it)
* programming clock (if you are not sure then try less than 100kHz)
crazy-igzp is offline   Reply With Quote
Old 08-16-2016, 04:20 PM   #3
RobertBil
RobertBil is on a distinguished road
Hi..i worked on many projects using the ATmega128 and as per my knowledge the problem is there because of faulty firmware. This happened because of that only. Also as suggested above check your CLK and power supply as well as programming CLK.
pcb assembly supplier
RobertBil is offline   Reply With Quote
Old 08-18-2016, 11:11 AM   #4
Em_13
Hi RobertBil
The problem was in the inverse bit programming
What programmer you use?
Old 08-21-2016, 09:05 AM   #5
I use a calculator Fyuz. I'm changing only the frequency setting.
Old 08-28-2016, 09:55 AM   #6
Jon
Jon is on a distinguished road
The future for Arduino
There are no such problems with installations.
Jon is offline   Reply With Quote
UART Atmega128 is not working Anatoly Microcontrollers (MCU) 5 01-25-2016 09:13 AM
PIC16F676 5k Potentiometer Analog Read Ali_Ahmer Microcontrollers (MCU) 3 01-15-2016 06:26 PM
Modem AT command error Rocketman46 Microcontrollers (MCU) 1 01-03-2016 09:11 AM
Glass Tube Fuse Identification havovh Electronic Components 0 10-31-2015 01:00 PM
Simple ATmega8 fuse bit doctor vgeorgiev Microcontrollers (MCU) 2 11-08-2014 06:38 PM
