Old 09-11-2016, 05:10 PM   #1
Em_13
Em_13 is on a distinguished road
Default msp430 and counter of timers
with MSP430G2553, I control 4 switches with timers. Timers 1.0 and counts TA1.1 can determine the period for key1. TA0.0 is TA0.1 can determine the period for switch2. What can ı do for switch3 and switch4. All duty cyles and frequency are the same for each switch, but no switch open at a time. for example, switches 1 MHz and a duty cycle of 80%. this switch opens and closes 50 times then stopped. I check my control algorithm is then another switch or the same switch may again cycle, but do not forget not 2 switch to work at the same time.
Is there anything I can do to increase the number of timers ?
Em_13 is offline   Reply With Quote
Old 09-12-2016, 02:22 PM   #2
if there is a common minimal time interval for all four switches, you can use this to create s/W planned to create additional counter to determine the on/off time of each switching.
Old 09-15-2016, 02:56 PM   #3
Em_13
The switches are transistors. I use the Timer modules to control them. The frequency of this switches 6 kHz duty cycle, %53. I was referring to the number of timers, sorry, my fault.
Old 09-19-2016, 04:21 PM   #4
wjoifeh
wjoifeh is on a distinguished road
So you Board and msp430, and then FET transistors, which can be controlled with [0~3V] signals?
wjoifeh is offline   Reply With Quote
Old 10-02-2016, 11:30 AM   #5
Em_13
The switches are transistors. I use the Timer modules to control them. The frequency of this switches 6 kHz duty cycle %53.
PIC16F870 frequency counter Anatoly Microcontrollers (MCU) 1 05-04-2015 08:56 PM
Modeling counter in Proteus rapid Beginners 2 01-18-2014 02:34 PM
Discussion: Bluetooth MSP430 Tank Radiolocman Robot Projects and Advices 1 12-22-2013 08:57 PM
Discussion: A Designer's Guide to Watchdog Timers. Part 1 - Overview and features Radiolocman Robot Microcontrollers (MCU) 1 11-11-2013 11:46 AM
Discussion: Eight-digit counter works with common anode or common cathode Radiolocman Robot Projects and Advices 1 09-04-2012 04:14 AM
