Old 10-19-2016, 09:11 AM   #1
jeccik
jeccik is on a distinguished road
Default MCU Output Driver Verification
I am creating a circuit in which a MCU (STM32) must drive 12VDC outputs, and wanted to make sure there wasn't anything missing in my driver circuit for the outputs.
-R1 is the inrush current limiting resistor
-R2 is the pull-down resister to keep the mosfet gate low if the MCU pin floats,
-D1 is the flyback diode, for protection against inductive loads, which will be a use case.
PS: I forgot to change the diode in the circuit, the actual part number is GSD2004W
The load will be connected to the 12V power line and the ground will be switched via the out pin.
The expected load will be practically anything as long as it is 12V and less than 250mA. But there will definitely be relay coils, indicator lights, and solid state relays attached to the output.
If there is anything I am missing that would be necessary or even a good idea or small improvement to include? I just don't want to spin a board with this and find out something wasn't working as intended, so some assurance would be nice.
jeccik is offline   Reply With Quote
Old 10-19-2016, 07:14 PM   #2
In principle, all right. However, I would like to note the following (my personal opinion):
- resistor R1 - 220 Ohms
- resistor R2 - 10 kOhm, I think it is quite enough
diode D1 - I don't think that this will suit you, for you load. When selecting a diode should be based on a set of parameters, one of which is the relay coil current. In general, suitable diodes 4007, M7
MOSFET 2N7002 - the maximum drain current (if the manufacturer NXP) 300 mA - I think you have to choose another transistor. And by the way, the transistor has a built-in diode. See. Datasheets
Old 10-26-2016, 04:55 PM   #3
ravicoolit
ravicoolit is on a distinguished road
jeccik, put a transistor IRFZ44
ravicoolit is offline   Reply With Quote
2 transistor circuit input output question brandonb916 Beginners 2 01-29-2016 02:33 PM
Using Arduino to high current 12volts inputs and output tracert Microcontrollers (MCU) 2 12-06-2015 06:09 PM
Software to control COM or Parallel port pin output tracert Microcontrollers (MCU) 1 08-16-2015 07:47 AM
Discussion: MMA7455L Three Axis Digital Output Accelerometer Radiolocman Robot Microcontrollers (MCU) 1 05-13-2015 06:01 PM
Datasheet MCU STM32F100R4T6B First Electronic Components 1 12-31-2010 06:52 PM
