RadioLocman.com Electronics ru
Advanced Search +
Go Back   RadioLocman Forum > Electronics and ... > Microcontrollers (MCU)
Microcontrollers (MCU) Application and programming of MCUs, Evaluation Kits and Demonstration Boards, Programmers.
Reply
Thread Tools Search this Thread
Old 08-29-2017, 03:59 PM   #1
Em_13
Junior Member
Em_13 is on a distinguished road
Default I Cooked my Arduino 3G module? SIM5320E
So I played with the SIM5320E, which is similar to the SIM900, but uses 3G. In short, I can short-circuit the antenna signal wire with 5V Arduino. Or a signal wire with GND. Or, maybe I accidentally connected 5V Arduino to the GND modules. I have no idea, but it immediately caused an unpleasant smell, but I did not see any visible smoke. The reason they were concerned was my mistake, I had an antenna tucked under some wires for convenience so that it would not just burst around in the wind. I use the arduino nano recorded on the back of the module, and when I moved it, either the antenna signal, or gnd, connected to 5V or gnd arduino.
Em_13 is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Discussion: Dual 13A μModule regulator with digital interface for remote monitoring & control of power Radiolocman Robot Projects and Advices 1 02-20-2016 08:47 PM
Discussion: One wire brings power & data to LCD module Radiolocman Robot Projects and Advices 1 04-19-2015 06:12 PM
Discussion: Serial four digit 7-segment LED display module Radiolocman Robot Projects and Advices 1 07-24-2012 11:53 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Slices ↓
Radiolocman facebook Radiolocman twitter Radiolocman google plus
