Old 01-17-2016, 06:21 PM   #1
Cjuried
Cjuried is on a distinguished road
Default TDA7052A and LM386 in low voltage power amp designs
I am interested, in the groups consensus, with respect to using a TDA7052A in place of the common LM386 in low voltage amp designs. General topic, but nevertheless, should spark some interesting bullet points. Thanks in advance.
Cjuried is offline   Reply With Quote
Old 01-19-2016, 08:06 AM   #2
The LM386 is a single low power amplifier.
The TDA7052A has two amplifiers in a bridge for double the output power and it also has a voltage controlled volume control.
Old 01-20-2016, 04:52 PM   #3
maks
maks is on a distinguished road
They both have the same amount of distortion so they will sound the same. Except some have lower distortion and some have higher distortion. So you will actually have different gain, different maximum power output and different distortion. The TDA7052 and TDA7052A are not available anymore in a DIP package.
maks is offline   Reply With Quote
Old 01-21-2016, 12:31 PM   #4
Cjuried
Boy is it ever. Assuming we are using an equivalent Voltage gain and Power output (substitute LM386N-4 in place of LM386 and TDA7052 in place of TDA7052A) with both these amplifiers, please describe your take on their "sonic characteristics".
Discussion: NE555 timer sparks low-cost voltage-to-frequency converter Radiolocman Robot Projects and Advices 1 10-04-2015 01:05 PM
Capacitors & Resistors in Amplifiers DRN_231 Beginners 1 08-28-2015 06:58 PM
Power amp fan trouble Jon Beginners 0 07-11-2015 09:52 AM
Discussion: One wire brings power & data to LCD module Radiolocman Robot Projects and Advices 1 04-19-2015 06:12 PM
Discussion: Simple Circuit Communicates Over Low-Voltage Power Lines Radiolocman Robot Projects and Advices 1 12-01-2013 05:41 PM
