Old 11-14-2015, 08:51 AM   #1
Default Need a simple latch circuit using logic gates
In my current project, a 3 to 8 decoder that takes input from a PICAXE 08M2, splits it into 2 sets of 4 outputs (from the 8) and powers a 4x4 array of LEDs. I came across a problem, the 3 to 8 decoder (I built from inverters and 2 input AND gates) can only output one thing at a time, so because I have 4 total outputs from my picaxe 08M2 I can use it with my passive matrix like so:
output column controller 'pin' (1-4)
put into latching circuit with 'timer' ouput from picaxe
stop outputting column controller pin
latch stays on as long as latch circuit gets 1 of 2 inputs
ouput row controller pin (5-8)
hold for as long as needed
(the timer tells the circuit how long to hold the column controller pin)
Does that make sense?
I'll supply a schematic if it's critical but these previous parts of the circuit aren't important to me, the important thing is the latching part.
TL;DR
Think of it like I get 2 inputs, and I want to hold them as long as one of the two is on. Then output that to an LED.
My idea is to use an AND gate, and feed the output back into the input via a diode so that it will stay on. Here's a schem:
Here's a link instead
http://www.digikey.com/schemeit/#c3k
The problem with this circuit is with S1 I think, because if I use a switch and try the circuit, if it's on, it stays on as long is S2 is closed the whole time. That's just what I want.
But, if I use an automated on-off system via a uController it doesn't work (except by accident once, and I can't replicate). A new idea comes to mind to use an OR gate and feed that into the place of S1, will that work? Does anyone know why the AND latch doesn't work if it's input is from an AND gate that gets it's input from a picaxe? PLEASE help! It's day 4 of this project and I'm exhausted, this is as close to the last step as I've ever been.
Old 11-16-2015, 02:44 PM   #2
The schematic doesn't show in the forum. Is it on a server with limited access?
Need 500pF 10Kv doorknob capacitors Anatoly Electronic Components 0 08-10-2015 05:28 PM
Discussion: Simple circuit indicates a low battery Radiolocman Robot Projects and Advices 2 02-10-2015 05:37 PM
Discussion: Simple circuit lets you characterize JFETs Radiolocman Robot Projects and Advices 1 12-13-2013 04:45 PM
Discussion: Simple Circuit Communicates Over Low-Voltage Power Lines Radiolocman Robot Projects and Advices 1 12-01-2013 05:41 PM
Discussion: mini Logic analyzer on AVR Microcontroller Radiolocman Robot Projects and Advices 1 11-24-2013 07:59 PM
