Old 06-05-2015, 10:35 AM   #1
Jon
Jon is on a distinguished road
Default How do i connect a reed switch to a microprocessor?
Hi
I want to connect a reed switch (Model: ct05) to a Zigbee SoC cc2430 chip.
Can anyone tell me how i should wire this up ?
Thank you
Jon is offline   Reply With Quote
Old 06-10-2015, 02:37 PM   #2
Not many replies to be found in here..
Well, you simply connect one end of the reed to ground, the other to the input, and a pull-up resistor (1-100k) from the same input and up to Vcc. The input goes low when the reed is activated by a magnet.
How to write data to the Eeprom segment ? Jon Microcontrollers (MCU) 3 05-27-2015 10:54 AM
How to connect the led power 10 W ? mark Beginners 1 05-20-2015 11:47 AM
Discussion: Connect a 43 matrix keyboard to a microcontroller using two I/O pins Radiolocman Robot Projects and Advices 1 12-23-2013 04:00 PM
Connect LEDs to the 220V mark Beginners 3 11-30-2013 11:08 AM
Discussion: How to Charge Any USB Device by Riding Your Bike Radiolocman Robot Projects and Advices 1 12-01-2011 02:20 PM
