Old 07-01-2015, 05:33 PM   #1
Default How to connect a stepper motor to a bipolar driver
I have a big problem to connect my stepper motor to a bipolar dirver.
On the driver I have several inputs including (pulse+, pulse-, direction +, direction -, enable +, enable -) etc.
And the outputs: motor phase A, and phase B.
Questions:
1) my motor has 6 wires. And I have only 4 inputs on my driver!! what should I do with the 2 other wires?
2) Can you please tell me if I can find a good tutorial to understand these connections?
Old 07-04-2015, 05:02 PM   #2
Two of the 6 wires will be center taps of 2 others. I.e. there are actually two center-tapped coils. Use an Ohmmeter to determine which wires are which, and then just ignore the center tap wires.
Old 07-04-2015, 05:04 PM   #3
OK, thanks
How do i connect a reed switch to a microprocessor? Jon Microcontrollers (MCU) 1 06-10-2015 02:37 PM
How I can configure an AVR microcontroller PWM to find the set point using a servo (DC ) motor? tracert Microcontrollers (MCU) 1 06-04-2015 06:37 AM
How to write data to the Eeprom segment ? Jon Microcontrollers (MCU) 3 05-27-2015 10:54 AM
How to connect the led power 10 W ? mark Beginners 1 05-20-2015 11:47 AM
Connect LEDs to the 220V mark Beginners 3 11-30-2013 11:08 AM
