New 96 Percent Efficient, 3 mm x 3 mm ICs Help Expand Market Opportunities for Battery-Powered Applications
Oct. 14, 2003 - Texas Instruments Incorporated (TI) announced a family of synchronous 1.5-A switch DC/DC boost converters with linear regulation functionality for battery-powered electronics. The converters reduce board space, provide up to 96 percent power conversion efficiency from an input voltage range of 0.9 V to 5.5 V, and enable designers to power innovative applications such as a white LED flash for wireless camera phones. See:'power.ti.com/sc03219.TI's new TPS6102x family of converters support power supplies for personal digital assistants (PDAs), PC peripherals, wireless headsets and other products powered by either a one-cell, two-cell or three-cell alkaline, nickel-cadmium (NiCd), nickel metal-hydride (NiMH), or a one-cell lithium-ion (Li-Ion) or lithium-polymer (Li-Poly) battery. The highly flexible converters provide 200 mA from a 0.9-V input when using a single-cell alkaline battery. The TPS6102x can also be used for generating 5 V at 500 mA from a 3.3-V rail or a Li-Ion battery at up to 96 percent power conversion efficiency.
For applications that require a dual output, the popular TPS611xx family of DC/DC boost converters with integrated LDO features two independent voltage regulators in a small 4 mm by 4 mm QFN package. For more information on the TPS611xx family, see:'power.ti.com/sc02209.
Additonal Features of the TPS6102x:
- 25 µA (Typ) Quiescent Current'
- Adjustable Output Voltage up to 5.5 V with Fixed Output Voltage Options
- Output Voltage Remains Regulated When Input Voltage Exceeds Nominal Output Voltage'
- Low Battery Comparator'
- Over-Temperature Protection
The TPS6102x family of converters is available today in volume from TI and its authorized distributors. The synchronous DC/DC converters come in a 10-pin 3 mm x 3 mm QFN package, and are priced in quantities of 1,000 at $1.39 per unit. Evaluation modules of the TPS61020 are available in less than 24 hours through'power.ti.com.
