International Rectifier Introduces Rugged and Reliable Power IGBTs that Improve Appliance and Industrial Motor Drive Performance
October 16, 2003- International Rectifier, IR® introduces a pair of 600V 50A non-punch-through (NPT) discrete IGBTs for motor drive applications in D2Pak and TO-220. These IGBTs feature a "square" reverse bias safe operating area (RBSOA) and 10microseconds short-circuit capability, which improves motor drive ruggedness and reliability. A square RBSOA means that the current rating does not degrade at higher voltage. IR's new IGBTs are ideal for hard-starting motor drive applications with high in-rush currents up to 6kW. Typical applications span from vacuum systems to switch reluctance (SR) drives and UPS systems.
IR's thin silicon NPT technology offers lower turn-off energy losses, allowing operation at high frequencies without any increase in conduction losses and reduced thermal resistance. The new devices can operate up to 175°C junction temperature, achieving a maximum current rating of 50A.
New International Rectifier 50A, 600V Appliance and Industrial NPT IGBTs
Part Number Package VCES(V) IC max @ TC 100°C (A) VCE(ON) typ. @ TJ 25°C Ic=30A (V) Eswitch @ TJ 150°C (mJ) Power Level Max.
IRGS30B60K D2Pak 600 50 1.95 1.785 Up to 6kW
IRGB30B60K TO-220 600 50 1.95 1.785 Up to 6kW
Availability and Pricing
The new 600V NPT IGBTs are available immediately. Pricing begins at US $0.93 each in 10,000-unit quantities for the IRGB30B60K.
