FZLED 22-watt PAR38 LED spotlights with dimming function now available
FZLED PAR38
FZLED, maker of high-performance LED lighting products, releases their new line of 22-Watt PAR38 LED Spotlights that have lifetimes of more than 35,000 hours. Fitting standard E26/E27 sockets, these high performance LED spotlights provide as much as 1400 luminous flux and give consumers the choice between a clear or frosted lens. Furthermore, users can choose for their bulbs to come with or without FZLED's built-in, dimming feature, allowing the spotlights to function at 12%, 25%, 50%, or 100% of light intensity. The desired level of brightness is easily selected by pressing the on/off power switch multiple times. Conforming to FZLED's high quality standards, these dimming LED spotlights give users an energy-saving, high-brightness, environmentally-friendly lighting solution.
FZLED - PAR38
Consumers can choose between a “warm white” 3000K CCT or a “cool white” 6000K CCT that provide luminous fluxes (lm) of 1200 and 1400, respectively. The FZLED 22-Watt PAR38 energy-efficient LED spotlights have a beam angle of 120°, an AC input voltage range of 90-264V, and can be placed directly into standard E26/E27 sockets, hassle free. With driver efficiency greater than 80%, a high energy-to-light conversion ratio, and a thermally optimized design, these LED spotlights are built to last and give consumers the best lighting solution available.
Applications
  • Indoor Lighting
  • Architectural Lighting
  • Flood Lighting
  • Mood Lighting
  • Biological Lighting
Features
  • Dimming or Non-Dimming
  • Energy Saving
  • No heat, No UV, or IR light radiation
  • Light source: High power LED
  • Ra > 75 for white light
  • Long lifetime > 35,000 hours
  • E26/E27 socket compatible
  • High power driver efficiency > 80%
  • CE, FCC and ETL Approved
ledsmagazine.com
