Miniature SMD Oscillator with 32.768 kHz
Jauch JRO32 JO75
Jauch announces a new Oscillator device. The JRO32 is a very small size SMD oscillator which is only offered in a frequency of 32.7680 kHz. It uses a tuning fork crystal internally and is designed for a very low power consumption. The JRO32 may typically be used for battery powered applications to feed real time clock devices (RTC).
Background:
After the introduction of the new JRO32 type, Jauch can offer two oscillator types in a frequency of 32.768 kHz. There are several basic differences between JRO32 and JO75 low frequency type" which are explained below.
Jauch - JRO32
The JO75 uses an AT cut crystal and is available for temp. stabilities of ±100ppm down to ±25ppm in operating temperature range of –40°C ~ +85°C or ±20ppm in –10°C ~ +70°C. It offers a HCMOS compatible output with "normal" rise & fall times (6nsec. max.) required to drive standard logic.
The JRO32 uses a tuning fork crystal, so the temperature stability curve looks like a tuning fork crystal. The JRO32 is especially designed for lowest power consumption, and therefore it has an output signal with a "slow" output rise & fall time (200nsec. max.).
Consequently, the customer must decide according to his application which would be the best matching type:
  • JRO32 for lowest power consumption, stability comparable to tuning fork crystals or
  • JO75 for better temperature stability and wider temperature range.
Key-Features of the JRO32:
  • standard miniature-package:3.2mm x 2.5mm x 1.0mm
  • variable supply voltage-1.5V ~ 5.0V
  • low power type for Real Time Clocks (RTC)
  • uses tuning fork crystal
  • with Tristate Function
  • ceramic / metal package
  • suitable for Lead-free soldering process at 260°C max
  • RoHS compliant
jauch.de
