TI high-temperature H.E.A.T. evaluation module speeds safe testing of electronics for harsh and hot environments
Texas Instruments HEATEVM
Complete signal acquisition system qualified for high temperatures up to 200ºC, test oven ready
Texas Instruments Incorporated introduced the H.E.A.T. (harsh environment acquisition terminal) evaluation module (EVM), the industry's first high-temperature data acquisition system, which includes a complete set of TI signal chain components qualified for extreme temperature operation from -55ºC to 210ºC. The H.E.A.T. EVM is test-oven ready and qualified to operate up to 200 hours at oven temperatures of up to 200ºC. It accepts eight channels of analog data and conditions, digitizes and processes these signals for a variety of applications in ruggedized, high-temperature environments including downhole drilling, jet engines and heavy industrial applications.
Texas Instruments Incorporated: H.E.A.T. EVM
Click to enlarge
The H.E.A.T. EVM eliminates the need for expensive up-screening and qualification testing of industrial-grade components for temperature ranges outside their datasheet specifications. The tool allows manufacturers to develop applications with components qualified for harsh environments quickly and safely and cuts development, testing and qualification time by up to one year. For H.E.A.T. EVM details or to order, see www.ti.com/heat-pr
Key features and benefits of the H.E.A.T. EVM
  • Six channels optimized for temperature, pressure sensors and accelerometers plus two general-purpose channels (fully differential and single-ended).
  • Comprehensive set of components qualified for operating temperatures from -55ºC to 210ºC and guaranteed for at least 1,000 hours operating life.
  • Made with polyimide material, and incorporating high-temperature rated passive components and high-temperature solder material, the EVM is test oven ready and can withstand temperatures of up to 200ºC for 200 operating hours.
Tools, availability and pricing
The H.E.A.T. EVM complements TI's full portfolio of analog and embedded processing products for high-temperature, high-reliability environments. The board is immediately available for $5,749.
ti.com
