Texas Instruments introduces highly efficient boost charger IC for nano power energy harvesting
Texas Instruments bq25504
330-nA quiescent current and 330-mV cold-start capability help make wireless sensor networks more cost-effective
Texas Instruments introduced its next generation of power management integrated circuits (ICs) for energy harvesting. The highly efficient boost charger for nano (ultra low) power energy harvesting manages the microwatts to milliwatts of power generated from a number of sources, such as solar, thermoelectric, electromagnetic and vibration, and stores the extracted energy in various storage elements, including Li-ion batteries and super capacitors. The bq25504 also includes circuitry to protect the energy storage element from over voltage and under voltage conditions and to kick-start the system when the battery is deeply discharged.
Texas Instruments - bq25504
In a solar panel powering a handheld device that is operating in indoor light conditions, for example, the new boost charger increases the usable harvested energy by 30 to 70 percent compared to a linear regulator. This efficiency allows designers to reduce the size and the number of solar panels in their designs, thus reducing overall solution cost. The device can benefit wireless sensor networks (WSN) for area, industrial, water/waste and structural monitoring, along with consumer, high reliability and medical applications.
Key features and benefits
  • Low quiescent current, typically 330 nA, and high conversion efficiency of greater than 80 percent maximize the energy extracted from the energy harvester.
  • Maximum power point tracking (MPPT) optimizes energy extracted from DC harvesters, such as solar panels under varying light conditions and thermoelectric generators (TEG) under varying thermal conditions.
  • User-programmable settings allow the boost charger IC to be used with a variety of energy sources and energy storage elements, such as different battery chemistries or super capacitors.
  • Low cold start voltage, typically 330 mV, allows the bq25504 to start up from single-cell solar panels under low light, as well as TEGs with low temperature differences and other low-voltage sources.
  • Battery OK indicator allows conditional enabling of external loads and protects the storage element.
Availability and pricing
The bq25504 boost converter is available now in a 3-mm x 3-mm VQFN package, priced at $2.10 in quantities of 1,000.
ti.com
