Infineon's BCR205W is an easy-to-use LED controller with a minimum supply voltage just 0.2V higher than the forward voltage of LEDs. As a result, it can be used to control the maximum number of LEDs in series.
The controller features a scalable external output stage, which gives developers the freedom to use different LED types. BCR205W is ideal for driving low- power LEDs with up to 80mA driving current in combination with a bipolar transistor such as BC817K-40.
Application example using the BCR108 digital transistor for a typical output current of 30mA |
Features
- Operating voltage: [ 0,2V + VfLED ] to 18V
- Output current: 5mA to 88mA with external transistor
- Tailored to drive LEDs up to 0,2W
- Only 0,2V voltage overhead at 30mA LED current
- Typical 3% output current accuracy
- RoHs complient (pb-free)
- Small SOT343 package
Applications
- Channel letters for advertising
- LED strips for decorative lighting
- Aircraft, train, ship illumination
- Refridgerator, white goods lighting
- Architectural lighting
- Shop lighting
