Voltage References Combine Ultra-Low Noise, High Accuracy and Value for Precision Applications
Analog Devices ADR4520 ADR4525 ADR4530 ADR4533 ADR4540 ADR4550
Analog Devices introduced a series of voltage references offering the industry’s best combination of noise performance, initial output voltage accuracy, low temperature coefficient (TC), and excellent long-term stability at unmatched price points. The new ADR45xx series of voltage references are specifically suited for high-resolution data converters and precision applications in data acquisition systems, instrumentation, process control, and automotive battery monitoring.
Analog Devices - ADR4520, ADR4525, ADR4530, ADR4533, ADR4540, ADR4550
With low frequency noise of 0.5 ppm, maximum temperature coefficient of 2 ppm/°C over the full operating temperature range of –40 °C to +125 °C, and a typical long-term drift of only 25 ppm/1khr, the ADR45xx series of voltage references provide high accuracy over time and temperature variations critical for many precision applications. This performance is achieved with a maximum quiescent current of 950 µA and $3.45 price, making the devices ideal for portable and budget sensitive designs. Also available is an A-grade version with a TC of 5 ppm/°C at $2.45.
ADR45xx Voltage References Key Features:
  • Maximum TC: 2 ppm/°C
  • Output noise (0.1 – 10 Hz): < 1µVP-P @ 2.048 VOUT typical
  • Initial output voltage error: ±0.02 percent (max)
  • Input voltage range: 3 V to 15 V
  • Operating temperature: -40 °C to +125 °C
  • Output current: +10 mA source/-10 mA sink
  • Low quiescent current: 950 µA (max)
  • Low dropout voltage: 300 mV @ 2 mA (VOUT ≥ 3 V)
Availability and Pricing
Product
Output
Voltage
(V)
Sample and Full
Production
Availability
Price Each Per 1,000
B-grade
(TC of 2 ppm/°C)
A-grade
(TC of 5 ppm/°C)
Packaging
ADR4520
2.048
Now
$3.45
$2.45
SOIC-8
ADR4525
2.500
Now
$3.45
$2.45
SOIC-8
ADR4530
3.000
Now
$3.45
$2.45
SOIC-8
ADR4533
3.300
Now
$3.45
$2.45
SOIC-8
ADR4540
4.096
Now
$3.45
$2.45
SOIC-8
ADR4550
5.000
Now
$3.45
$2.45
SOIC-8
The ADR45xx series of voltage references is well suited to operate with many of ADI’s low power, precision A/D converters such as the AD7685, AD7982 and AD7988-1/-5, as well as D/A converters, including the AD5780 and AD5764.
analog.com
