IR's Compact PowIRaudio Modules Reduce Component Count, Shrink PCB Size up to 70 Percent and Simplify Class D Amplifier Design
International Rectifier IR4301M IR4302M
International Rectifier introduced the PowIraudio™ family of integrated power modules for high performance home theater systems and car audio amplifiers. The new devices integrate a PWM controller and two digital audio power MOSFETs in a single package to offer a highly efficient, compact solution that reduces component count, shrinks PCB size up to 70 percent and simplifies Class D amplifier design.
The combination of an advanced audio controller IC with MOSFETs fully optimized for audio performance results in improved efficiency, THD, and EMI, allowing the IR43xxM family operate without a mechanical heatsink over a wide power supply range on either a single or split power supply. High voltage ratings and noise immunity ensure reliable operation over various environmental conditions.
International Rectifier - PowIraudio
The single channel IR4301M and dual channel IR4302M offer the flexibility and convenience of building stereo amplifier and multi-channel designs in various channel configurations, while the devices’ 5×6 mm and 7×7 mm PQFN packages enhance the benefit of utilizing a smaller size of Class D topology.
Other key features common to the family include over-current protection, thermal shutdown, internal/external shutdown and floating differential input. The IR4302M also offers clip detection.
A wide range of reference designs are available to further simplify the design of systems using these devices.
Module Specifications
Part Number
No. of
channels
Power Supply
Voltage
Peak Output
(RMS per CH)
Package
IR4301MPbF
1
80V or ±40V
130W
PQFN 5×6mm
IR4302MPbF
2
80V or ±40V
70W
PQFN 7×7mm
Reference designs
Reference
Design
Featured
Part
Descriptions
Output Power
IR4301M
IR4301 split power supply
130W×2ch 4Ohms load/no heatsink
IR4302M
IR4302 split power supply
70W×2ch 4Ohms load/no heatsink
IR4302M
IR4302 single power supply
100W×2ch 4Ohms load/with heatsink
IR4301M
IR4301 single power supply
130W×2ch 4Ohms load/with heatsink
IRS27952S
Audio AC/DC power supply
120W ±30V
Availability and Pricing
Pricing for the IR43xx begins at US $2.00 in 10,000-unit quantities. Pricing is subject to change without notice. Production orders are available immediately. The new devices are MSL2 industrial-qualified and RoHS compliant.
irf.com
