Panasonic's New Memory Cards Are Survivors of the Extreme
Panasonic RP-SDAB08GJK RP-SDAB16GJK RP-SDAB32GJK RP-SDUB08GJK RP-SDUB16GJK RP-SDUB32GJK RP-SDUB64GJK
There are rugged consumer electronics devices and components, and then there are the Panasonic UHS-I-level SDAB and SDUB series of SDHC and SDXC memory cards.
Panasonic's memory cards reach the upper limit of what is recommended for consumer and business gadgets and then smash through it and keep going for a while longer.
Panasonic - UHS-I-level SDAB and SDUB
For one, the cards can be submerged underwater at a depth of 3.3 feet (one meter) and left there for half an hour without any ill effects. Secondly, the products are resistant to magnetic energy and will weather even direct electrical shocks without a hitch. Thirdly, the NAND Flash-based storage cards are resistant against X-Ray radiation.
Only the tolerance for cold is relatively tame (-13 degrees Fahrenheit / -25 degrees Celsius), but even that is completely compensated (to say the least) by the heat resistance (185 degrees Fahrenheit / 85 degrees Celsius).
Panasonic was able to implement this advanced physical toughness, along with fused insides (to prevent fire from burning the cards from within) without sacrificing performance. Weather-resistant cameras and other equipment taken to unfriendly environments will benefit greatly from their use.
Thus, the SDAB (8 to 32 GB) read data at 95 MB/s and write it at 80 MB/s, while the SDUB (8 to 64 GB) read at 90 MB/s and write at 45 MB/s.
We don't know what the prices are, unfortunately, and we probably won't learn them until Panasonic sends the cards to EU or the US, if ever. Right now, they are only official in Japan.
news.softpedia.com
