Dual 16-BIT, 1.6-GSPS, TXDAC + D/A converter synthesizes high-quality wideband signals from baseband to high intermediate frequencies
Analog Devices AD9142
ADI’s AD9142 D/A converter features a proprietary low spurious and distortion design with on-chip, numerically-controlled oscillator and integrated interpolation filters.
Analog Devices introduced the AD9142 dual-channel, 16-bit, 1.6-GSPS D/A converter, which supports high data rates and complex modulation schemes required in communications, test and instrumentation, and defense and aerospace systems.
The combination of programmable interpolation rate, high sample rates, and fine NCO modulation capability gives system designers flexibility when choosing D/A converter output frequencies. This is especially helpful in meeting four- to six-carrier GSM transmission specifications and other communications standards. Operating with the on-chip PLL (phase-locked loop) at a D/A converter output frequency of 200 MHz, the AD9142 delivers a 79-dB ACLR (adjacent-channel leakage ratio) for six-carrier GSM applications.
Analog Devices - LFCSP-72
The AD9142 includes integrated interpolation filters with selectable interpolation factors of 2, 4, and 8. The dual D/A converter data interface supports word and byte load allowing customers to reduce input pins on lower data rates to save board space, power and cost. The AD9142 is available in a space-saving 72-pin LFCSP (lead-frame chip-scale package).
Pricing, Availability and Complementary Products
Product Sample
Availability
Production
Release
Resolutione
(Bits)
Channels Sample Rate
(GSPS)
Price Each
In 1,000 Quantities
Packaging
AD9142 Now Now 16 2 1.6 $41.40 72-lead 10×10mm LFCSP
Complementary ADI components include the ADL537x and ADRF670x series quadrature modulators, and the AD9516 14-output clock generator IC.
analog.com
