Bourns announces new non-contacting rotary position sensors for heavy-duty applications
Bourns AMM20B AMS22U
In line with company’s commitment to provide products with innovative design, superior quality and exceptional value, Bourns Sensors and Controls announces the release of two models of non-contacting rotary position sensors.
Bourns Models AMM20B and AMS22U are designed to meet the specifications of heavy-duty applications requiring long cycle life and high reliability.
Non-Contacting Multiturn Rotary Position Sensor AMM20B
Bourns - AMM20B
This multiturn rotary sensor features a 12-bit resolution and factory programmable electrical angle from 1080 to 3600 degrees.
With a rotational life of up to 50 million cycles, the Bourns® Model AMM20B Sensor is a highly versatile multiturn position sensing device. Basic features and typical applications include the following:
Features
  • Non-contacting magnetic technology
  • Highly resistant to vibration/shock
  • Highly resistant to fluid/dust ingress
  • Programmable at factory for zero position
  • Robust design for industrial applications
  • Highly repeatable
  • RoHS compliant
Applications
  • Patient platform positioning feedback
  • Pneumatic control valve position feedback
  • Camera positioning
  • Actuator motor position feedback
  • Rudder positioning
  • Tilt control and tilt positioning feedback
  • Steering, lift-and-shuttle and suspension systems
Non-Contacting Analog Rotary Position Sensor AMS22U
Bourns - AMS22U
This single-turn rotary sensor features a 1/8” shaft supported by dual ball bearings and a factory programmable electrical angle from 10 to 360 degrees. Available in a servo mount configuration with a rotational life of up to 100 million cycles, Bourns® Model AMS22U Sensor is a highly versatile position sensing device. Basic features and applications include the following:
Features
  • Highly repeatable
  • RoHS compliant
Applications
  • Foot pedal, steering, lift-and-shuttle and suspension systems
Samples and production quantities of both devices are now available.
bourns.com
