New Vishay Siliconix Power MOSFETs Offer Industry-Low On-Resistance Down to 20 mΩ at 4.5 V in Chipscale MICRO FOOT 1 mm by 1 mm and 1.6 mm by 1.6 mm Packages
Vishay Si8424CDB Si8425DB Si8466EDB
Vishay Intertechnology introduced new 8 V and 20 V n-channel and p-channel TrenchFET® power MOSFETs with the industry’s lowest on-resistance in 1 mm by 1 mm by 0.55 mm and 1.6 mm by 1.6 mm by 0.6 mm CSP MICRO FOOT® packages.
The devices released will be used for battery or load switching in power management applications for portable electronics such as smartphones, tablet PCs, and mobile computing devices. The MOSFETs’ compact outlines save PCB space and provide ultra-thin profiles to enable slimmer and lighter portable electronics, while their low on-resistance translates into lower conduction losses for reduced power consumption and longer battery life between charges. The devices’ low on-resistance also means a lower voltage drop across the load switch to prevent unwanted under-voltage lockout.
Vishay - Si8424CDB, Si8425DB, Si8466EDB
For applications where low on-resistance is more critical than space, the 8 V n-channel Si8424CDB and - 20 V p-channel Si8425DB offer maximum on-resistance of 20 mΩ and 23 mΩ, respectively, at a 4.5 V gate drive. The devices are offered in the 1.6 mm by 1.6 mm by 0.6 mm CSP package. With 43 mΩ maximum on-resistance at 4.5 V, the smaller 1 mm by 1mm by 0.55 mmSi8466EDB 8 V n-channel MOSFET will be used for applications where space is even more critical than on-resistance. The Si8466EDB also provides 3000 V typical ESD protection.
The Si8466EDB and Si8424CDB offer on-resistance ratings down to 1.2 V, allowing the devices to work with the lower-voltage gate drives and lower bus voltages common in handheld devices, saving the space and cost of level-shifting circuitry. All devices are compliant to RoHS Directive 2011/65/EU and halogen-free according to the JEDEC JS709A definition.
Device Specification Table:
Part #
Polarity
N
N
P
VDS (V)
8
8
- 20
RDS(ON) (mΩ) max. @
4.5 V
43
20
23
2.5 V
46
21
27
1.8 V
23
40
1.5 V
60
28
1.2 V
90
45
Outline (mm x mm)
1 × 1
1.6 × 1.6
1.6 × 1.6
Profile (mm)
0.55
0.6
0.6
Samples and production quantities of the new TrenchFET power MOSFET are available now, with lead times of 12 to 14 weeks for larger orders.
vishay.com
