Cree Announces Revolutionary LM16 LED Replacement Lamp to Obsolete Energy-Wasting Halogen MR16
Cree LM16
Latest Cree innovation uses single LED source to deliver precise optical control, glare-free lighting and lower energy cost
Using up to 80 percent less energy and designed to last up to eight times longer than traditional 50-watt halogen MR16 lamps, the Cree® LM16 LED Lamp delivers a new standard in LED lighting. The new Cree lamp can deliver payback in less than 12 months and provide years of consistent color quality and lumen output. The high-performance LM16 LED Lamp delivers the industry’s best center beam candlepower for 25° beam angles – making it ideal for a wide spectrum of applications in retail, hospitality and residential settings.
Cree - LM16
The new LM16 LED Lamp not only matches the performance, appearance and ANSI form factor of the traditional halogen lamp, but also works with a broad range of transformers and dimmers to seamlessly replace it in existing systems. Embedded protective dimming circuitry and intelligent thermal software in combination with the innovative Cree fanless housing design, help deliver a long lifetime of quality and performance.
The Cree LM16 50-watt halogen equivalent delivers 620 lumens (consuming only 9 W) and the 35-watt halogen equivalent delivers 425 lumens (consuming only 7 W). The new lamps are designed to provide a minimum of 25,000 operating hours, reducing the need to replace lamps. The 50-watt equivalent is dimmable to five percent on a broad range of dimmers and transformers. The new Cree LM16 LED Lamp is available in three beam angles, including 17° spot, 25° flood and 40° wide flood.
The Cree LM16 LED Lamp is sold through Cree lighting sales channels.
cree.com
