The New TS9002 Dual is $2.10 Less Expensive than MAX923 and the New TS9004 Quad Is $0.60 Less Expensive than MAX934.
Touchstone Semiconductor announced the TS9002 dual and the TS9004 quad low power analog comparators plus 1.182-V reference integrated circuits. As an improved, pin-for-pin functional equivalent to the MAX923, the TS9002’s 3.2-μA supply current is 16% lower and its ±0.75% initial accuracy voltage reference is 25% lower in both specifications compared to the MAX923. As an improved, pin-for-pin functional equivalent to the MAX934, the TS9004’s 4.1-μA supply current is 25% lower and its ±1% initial accuracy reference is 50% lower in both specifications compared to the MAX934.
Ideal for 3V or 5V single-supply applications, the TS9002 dual and the TS9004 quad comparator can operate from single +2.5V to +11V supplies or from ±1.25V to ±5V dual supplies.
Both comparators are designed for low-voltage, low-power applications, including threshold detectors/discriminators, oscillator circuits, window comparators, level translators, and other battery-powered systems.
TS9002 Dual Comparator Key Specifications:
- Priced at $0.75 in 1000-piece quantities - $2.10 Less Expensive than MAX923
- 16% Lower Supply Current: 3.2μA vs 4.1μA
- 25% Lower VREF Initial Accuracy: ±0.75% vs ±1%
- User-adjustable Hysteresis via External HYST Pin
TS9004 Quad Comparator Key Specifications:
- Priced at $1.15 in 1000-piece quantities - $0.60 Less Expensive than MAX934
- 25% Lower Supply Current: 4.1μA vs 5.5μA
- 50% Lower VREF Initial Accuracy: ±1% vs ±2%
- Separate GND Pin for Output Drivers
Both parts are fully specified over the -40 ºC to +85 ºC temperature range. The TS9002 is available in an 8-pin MSOP package and the TS9004 is available in a narrow 16-pin SOIC package.
