ASUS Launches B1M Ultra-bright Wireless LED Projector with 700 Lumens
ASUS B1M
Short-throw projector displays content over Wi-Fi from notebooks, tablets and smartphones.
ASUS announced the portable B1M Ultra-bright Wireless LED Projector with ASUS Wi-Fi Projection technology for presentations and media streaming without the need for cables. Designed for professional use, the B1M is a short-throw projector with a compact and lightweight design that makes it easy to carry in a briefcase or bag. The B1M features a bright 700 lumens Eco-LED light source with low operating temperatures and a long lifespan.
Asus - B1M
The ASUS B1M Ultra-bright Wireless LED Projector weighs just 900g and with a desktop footprint no larger than a DVD movie case, it’s easy to carry and can be used in even the smallest meeting rooms. The B1M lightens the load still further by drawing power from a standard ASUS notebook AC adapter (≥65W), removing the need to carry a separate power supply when used with a fully charged notebook.
The ASUS B1M features a small Wi-Fi adapter for a direct wireless connection to a notebook PC, or Android and iOS devices. This removes the need to carry a video cable solely for presentation use, and allows presentations, documents and multimedia files to be streamed to the B1M wirelessly from elsewhere in a room. An Android or iOS device can also be used as a wireless remote control.
The ASUS B1M features a mercury-free Eco-LED light source with a 30,000-hour lifespan to cut down on maintenance and bulb-replacement costs. With brightness rated at 700 lumens and updated DLP projection technology, the B1M gives a vibrant image with 100% NTSC color saturation at a crisp 1280 × 800 (WXGA) resolution.
The short-throw lens can project images with a diagonal up to 51 inches across from just one meter away from the projection surface, making the B1M ideal for presentations in small spaces.
Thanks to the low operating temperatures of its Eco-LED light source, the B1M has short warm-up and cool-down times that make it ready for use in as little as five seconds, and the projector can be switched off and packed away instantly.
A wide selection of video input ports means the ASUS B1M can be used with a wide selection of projection sources, while its USB port and SD card slot also allow projections to be made directly from a USB storage device or memory card. Built-in two-Watt stereo speakers powered by ASUS SonicMaster audio technology ensure loud and clear sound without the need for external speakers.
asus.com
