EQRE Oscillators deliver 0.4pSec Maximum RMS Phase Jitter with LVDS output logic
Ecliptek EQRE32 EQRE33
Ecliptek's new EQRE series of LVDS oscillators offer rms phase jitter performance as low as 0.2pSec maximum up to 164.000MHz. Available with supply voltages of 2.5VDC or 3.3VDC, these 2.5mm × 3.2mm SMD oscillator products offer great flexibility with frequency tolerance/stability performance as low as ±20ppm over commercial, extended commercial and industrial operating temperature ranges.
Ecliptek - EQRE32, EQRE33
These REACH 144 SVHC Compliant oscillators are ideal for a wide range of applications including: Interface Controllers, Fiber Channel, Gigabit Ethernet, Portable Devices, SATA/SAS and PCI Express products.
Technical Benefits
  • REACH 144 SVHC Compliant
  • High speed LVDS output with fast rise and fall times
  • Complementary output
  • Outstanding jitter and phase noise performance
  • Pad 1 or pad 2 Standby (tri-state, high impedance) output options
  • Wide operating temperature ranges available
  • Tight duty cycle option of 50% ±5%
  • Improved frequency stability through use of a bulk acoustic wave (BAW) quartz crystal resonator
  • Industry standard moisture sensitivity level 1 (MSL1) rated ceramic six pad SMD package
  • RoHS Compliant (Pb-free) with high temperature 260°C reflow capability
Circuit Applications
  • Clock Recovery
  • Phase-Locked Loop and Frequency Synthesis
  • Synthesizer or System Reference
  • Clock Distribution
  • Clock Translation and Multiplexing
ecliptek.com
