Avago releas multi-mode parallel optic transceiver module
Avago AFBR-8420Z
The Avago AFBR-8420Z is a 10-channel pluggable, multi-mode parallel optic transceiver module designed for high-density 100 G Ethernet and Optical Transport Network (OTN). The device is designed to maximize the delivery of 10 G data channels for 100 G networks supporting 100 Gbps SR10 and 10×10 Gbps Ethernet interconnects per IEEE 802.3ba Clause 86 and 802.3ae Clause 52. Furthermore, the device is interoperable with 40 G SR4 and Avago 10 G SR optical solutions.
Avago AFBR-8420Z
Features
  • Compliant to RoHS directives
  • Compliant to CFP2 industry agreement
  • Utilizes CFP2 “ALT1” electrical pin configuration for 10 wide electrical interfaces
  • Compliant to 100 GbE specifications 802.3 ba (100GBASE-SR10, CAUI and CPPI) up to 100 m OM3 and 150 m OM4 fiber
  • Interoperable with 10 GbE transceivers that are compliant to 802.3ae 10GBASE-SR specifications with receiver overload up to 2.4 dBm max
  • Links up to 100 meters using OM3 fiber and 150 meters using OM4 fiber
  • 850nm Vertical Cavity Surface Emitting Laser (VCSEL)
  • Class 1 eye safe per IEC60825-1 and CDRH
  • Wide case temperature range (0 °C to 70 °C)
  • Utilizes standard 24 lane optical fiber with MTP (MPO) optical connector for high density and thin, lightweight cable management
  • Diagnostic features per CFP2 using MDIO. Real-time monitoring of:
  • Transmitter average optical power
  • Received average optical power
  • Laser bias current
  • Temperature
  • Supply voltage
  • Mechanical specifications per CFP2 Agreement
  • Proven high-reliability 850 nm technology: Avago VCSEL array transmitter and Avago PIN array receiver
  • Integrated CDRs on each transmit and receive lane for CAUI compliance, which can be bypassed for lower power dissipation CPPI interfaces
Applications
  • 10×10 Gb/s Ethernet Interconnects (802.3 ae Clause 52)
  • 100 Gb/s Ethernet Interconnects (802.3 ba Clause 86)
  • Datacom/Telecom Switch and Router Connections
  • Data Aggregation and Density Applications
avagotech.com
