New 50Ω Hand-Flex Interconnect Cables - N-Type (F) Bulkhead Connector to SMA (M)
Mini-Circuits 141-SMNB
In our continued effort to bring our customers more options in off-the-shelf cable solutions, Mini-Circuits has introduced the 141-SMNB series to our line of Hand-Flex™ system interconnect cables. N-type female bulkhead connector with rugged, nickel-plated brass flange at one end is ideal for making secure connections directly to the front panel of rack-mounted equipment.  This feature eliminates the need for additional brackets or adapters, improving reliability and reducing overall system cost.
Durable, shielded, hand-formable construction enables bend radii as narrow as 8mm, accommodating tight connections in dense system configurations and reducing the risk of damage from bending.  Meeting MIL-STD-348, these interconnect cables provide secure connections, long life, and high reliability.
Available in a variety of lengths, 141-SMNB series cables cover applications from DC to 12.5 GHz with insertion loss as low as 0.3 dB depending on length and 21 dB return loss at 12.5 GHz.
Mini-Circuits.com
