4x16 G Compatible Short Waves (iSW4) 850 QSFP+ Parallel to the Optical Transceiver from Avago
Avago Technologies AFBR-79FIPZ
The Avago AFBR-79FIPZ is a 4-channel interoperable shortwave (iSW4) QSFP+ optical transceiver module designed for converged network systems. The AFBR-79FIPZ is capable of supporting either 4x16 G Fibre Channel (FC) or 4x10 G Ethernet over a 100 meter link distance. The device supports aggregate 64 G FC or 40 G Ethernet bandwidth for high-density, short-range data communications and interconnects.
Avago AFBR-79FIPZ
The AFBR-79FIPZ is designed to operate over multi-mode fiber systems using a nominal wavelength of 850 nm.  The device offers optical interoperability with 4x, 8x, and 16x Fibre Channel and 10 G Ethernet SFP+ modules through breakout cables.
Features
  • Compatible with proprietary links with data rates up to 16 Gbps
  • Links up to 100 m using OM4 MMF and 66 m using OM3 MMF at a maximum data rate of 16 Gbps
  • Interoperable with:
    • - 16x Fibre Channel FC-PI-5 compliant transceivers
    • - 10 G Ethernet compliant module per IEEE 802.3ae
    • 10 GBASE-SR standard
    • - Avago's 10G SFP+ USR transceivers, up to 125 m using
    • OM4 MMF and 100 m using OM3 MMF
  • Compatible with 4x and 8x Fibre Channel FC-PI-5 transceivers with respect to optical specifications
  • Compliant to industry-standard SFF-8436 QSFP+ Specification Revision 3.5
  • Compliant to the 40 GBASE-SR4 and nPPI specifications per IEEE 802.3ba D3.2
  • Power Level 1: Max Power < 1.5 W
  • High port density: 21mm horizontal port pitch
  • Operates at 16 Gbps per channel with 64b/66b coded data
  • 0 to 70°C case temperature operating range
  • Proven high reliability 85 nm technology: Avago VCSEL array transmitter and Avago PIN array receiver
  • Hot pluggable transceiver for easy of installation and servicing
  • Two Wire Serial (TWS) interface with maskable interrupts for expanded functionality
  • Utilizes a standard 12/8 lane optical fiber with MTP® (MPO) optical connector for high density and thin, light-weight cable management
Applications
  • Datacom/Telecom Switch & Router Connections
  • Data Aggregation and Backplane Applications
  • Proprietary Protocol and Density Applications
  • Converged Network Adaptors for Fibre Channel and Ethernet Traffic
avagotech.com
