The Avago AFCP-TN295J is a 10G/s transmitter optical subassembly (TOSA) device
Avago Technologies AFCP-TN295J
The Avago AFCP-TN295J is a 10 G/s transmitter optical subassembly (TOSA) device designed for wireless backhaul and metro Ethernet access networks. The device integrates a 1550 nm single mode edge-emitting laser and a micro-TEC in a small form-factor coaxial package. It is designed for use in small form-factor pluggable transceivers such as XFP and SFP+ and other types of optical modules for high-speed telecommunication and data applications including SONET OC-192, SDH STM-64 and 10 G Ethernet.
Avago AFCP-TN295J
Features
  • Ultra small form-factor 8-pin
  • Data rates up to 10 Gb/s
  • For use up to 20 km at 10 Gb/s
  • Up to +5 dBm typical optical output power
  • Temperature stabilized
  • Very low TEC power consumption
  • LC, SC receptacle or pigtailed versions available
  • 25 Ω single-ended data input
  • Case operating temperature range: -5 C to +85 C
  • Wavelength tunable to ITU-T standards covering the partial of C-band with extended channels
  • Suitable for use in 100 GHz channel spacing in DWDM systems
  • Supports 1470-1610 nm CWDM as well as TDM
Applications
  • XFP, SFP+, X2, XENPAK and Other Pluggable Transceivers
  • 300-pin Transponders for SONET/SDH and 10 GbE Interfaces
  • Line Cards
avagotech.com
