Maximum Power Meets Outstanding Integration in the New, Enhanced SPOC BTS5482SF Switch
Infineon BTS5482SF
BTS5482SF  is the latest addition to Infineon's  SPOC high power family. The new high-side smart power switch provides four channels and a host of embedded protective and logic functions in a PG-DSO-36 package.
Infineon BTS5482SF
BTS5482SF is unique to the market, offering the benefits of high integration and high power capability through very low ohmic channels. It builds on over a decade of field experience and Infineon’s leading position in the automotive integrated smart high-side switch market.
BTS5482SF is designed to control automotive exterior lighting. It supports high power loads on low ohmic channels, including HID lamps or 65 W/55 W lamps. The LED mode on the high ohmic channels enables it to be configured to drive bulbs and LEDs.
Application diagram controlling an external two-channel PROFET
Infineon BTS5482SF
Features
  • 8-bit serial peripheral interface (SPI) for control and diagnosis
  • Integrated control for two external smart power switches
  • Fail-safe handling via limp home mode
  • Dedicated LED mode for two channels (2 and 3)
  • 3.3 V and 5 V compatible logic pins
  • Active reverse battery protection (ReverSave™) by self turn-on
Applications
  • High-side power switches for 12 V grounded loads
  • Specifically designed for automotive lighting (lamps, HID, LEDs)
  • Suitable for automotive and industrial heating and energy distribution
  • Replacement of discrete chipsets as well as relays and fuses
infineon.com
