The new Rohde&Schwarz CMA180 radio test set uses state of the art digital measurement technology for testing analog radios
The R&S CMA180 radio test set enables manufacturers and service technicians to test analog radios in the 100 kHz to 3 GHz frequency range. Its large touchscreen and straightforward menu provide for especially simple and fast operation. The R&S CMA180 uses an integrated ARB generator for software implemented test signal generation. Users can generate any output signal with a bandwidth of up to 20 MHz – a feature normally offered only in radiocommunications testers several times more expensive.
Rohde & Schwarz CMA180
The R&S CMA180 is the world’s first radiocommunications tester that allows users to generate additional signals with just a few mouse clicks, such as interfering signals for co channel rejection measurements. Service technicians and test engineers can also use the instrument’s integrated sequencer to configure and run automatic test sequences.
The R&S CMA180 radio test set is designed for 100 W continuous input power and 150 W peak input power and is the only tester in its price class capable of processing such high input levels. Thanks to digital signal processing, the R&S CMA180 delivers extremely precise measurement results and is ideal for testing software defined radios.
For high precision power measurements, Rohde & Schwarz offers optional extremely linear power sensors that can also be used with the R&S CMA180.
rohde-schwarz.com
