Avago releas QSFP+ 3SR4 Pluggable Optical Transceiver Module for 10 G and 40 G Ethernet Applications
Avago AFBR-79E3PZ
The Avago AFBR-79E3PZ is a 4-channel QSFP+ pluggable optical transceiver module device with an integrated pull tab for 40 Gigabit Ethernet (40 GbE) applications supporting extended link distance up to 300 m (400 m) using OM3 (OM4) multimode fiber (MMF). The device is capable of inter-operating with IEEE 10 GBASE-SR compliant products that can manage higher incoming optical power.
Avago AFBR-79E3PZ
The AFBR-79E3PZ is a high performance transceiver module for short-range multi-lane data communication and interconnect applications. It integrates four data lanes in each direction with each lane operating at 10.3125 Gbps, giving an aggregated bandwidth of 40 Gbps. This transceiver can also be used for high density 10 Gigabit Ethernet applications. It allows optical interoperability up to 300 m (400 m) using OM3 (OM4) MMF with any 10 Gigabit Ethernet (10GbE) transceivers, compliant to the IEEE 802.3ae 10 GBASE-SR specifications with a minimum 1 dBm of receiver overload. It provides an effective port count of over 100 within 1 RU rack. The pull tab facilitates the insertion and extraction of the device in high port density environment. The device is designated as an QSFP+ 3SR4 solution, where the digit "3" represents 300m link distance using OM3 MMF.
The AFBR-79E3PZ is designed to operate over MMF systems using a nominal wavelength of 850 nm. The electrical interface uses a 38 contact edge type connector. The optical interface uses an 8 or 12 fiber MTP® (MPO) connector. The module incorporates Avago's proven integrated circuit and VCSEL technology to provide reliable long life, high performance, and consistent service.
Features
  • An alternative low-cost, low-power solution to IEEE 802.3ba 40GBASE-LR4 module that supports extended link distance up to 300 m OM3 (400 m OM4) MMF for data center applications
  • Compliant to the 40GbE IEEE 802.3ba-2010 specifications (40 GBASE-SR4 and XLPPI) and the IEEE 802.3ae 10 GBASE-SR optical specification on per channel basis with extended mean laser optical power
  • Supports link distance up to 300 m OM3 (400 m OM4) MMF when connected to Avago QSFP+ eSR4 module and up to 100 m OM3 (150 m OM4) MMF when connected to Avago QSFP+ SR4 module.
  • Supports optical interoperability up to 300 m OM3 (400 m OM4) MMF with IEEE 802.3ae 10GBASE-SR compliant modules that can manage receiving optical power up to +1 dBm.
  • Compliant to industry-standard QSFP+ SFF-8436 Specification Revision 4.1
  • Power level 1: max power < 1.5 W
  • High port density: 21mm horizontal port pitch
  • Pull tab: ease of transceiver insertion and extraction; tab color coded "Orange" for 3SR4 identification
  • Operates at 10.3125 Gbps per channel with 64b/66b encoded data
  • 0 to +70°C case temperature operating range
  • Proven high reliability 850 nm technology: Avago VCSEL array transmitter and Avago PIN array receiver
  • Hot pluggable transceiver for servicing and ease of installation
  • Two Wire Serial (TWS) interface with digital monitoring and maskable interrupts for expanded functionality
  • Utilizes a standard 12/8 lane optical fiber with MTP® (MPO) optical connector for high density and thin, light-weight cable management.
Applications
  • 40 GbE and High Density 10 GbE Interconnects
  • Datacom/Telecom Switch & Router Connections
  • Data Aggregation and Backplane Applications
  • Proprietary Protocol and Density Applications
Avagotech.com
