Avago Technologies Announced Release 3-Channel Reflective Incremental Encoder
Avago AEDR-872x
The Avago AEDR-872x is a 3-channel reflective optical encoder device providing dual channel analog outputs and an index channel digital output. The differential analog outputs (Sin, /Sin, Cos, /Cos) can interface directly with most commercially available interpolator devices for high precision motion control measurements. As such, the device provides great design-in flexibility and can enhance the performance of existing motion control system.
Avago AEDR-872x
The AEDR-872x houses an LED light source and a photo-detecting circuitry in a compact package. The miniature package coupled with low operating 5.0 V option allows the device to be used in a wide range of space-constrained, low-power applications like portable devices in which space and power dissipation are primary concern. The device is designed to operate over -20 to +85 °C temperature range suitable for both commercial and industrial end applications.
Features
  • 3 Channel Outputs
  • Dual Channel Analog Outputs
  • Index Channel Digital Ouput
  • Built-in Automatic LED Current Regulation
  • Encoding Resolution: 318 LPI
  • Power Supply Voltage: 5 V
  • Operating Temperature Range: -20 to +85 °C
  • Surface Mount Leadless Package: 3.95 mm (L) × 3.4 mm (W) × 0.956 mm (H)
Applications
  • Closed-loop Stepper Motors
  • Miniature Motors
  • Printers and Copiers
  • Card Readers
  • Scanners
  • Projectors
  • Portable Medical Equipment
  • Optometric Equipment
  • Consumer and Industrial Product Applications
Benefits
  • High Resolution
  • Compact Size
  • 3 Channel in 1 Solution
  • Sine/Cosine Analog Output
  • Flexibility in Radius
  • Low Power Consumption
  • SMT Reflowable Mount
  • Mounting Compatibility to AEDR-85XX
  • Cost Effectiveness
avagotech.com
