TI speeds Power over Ethernet development with next-generation PSE controller
Texas Instruments TPS23861
Two-layer evaluation module and reference design simplify PoE design in network video recorders and Ethernet switches
Easing design for rapidly growing Power over Ethernet (PoE) applications, Texas Instruments Incorporated (TI) introduced a two-layer PoE power sourcing equipment (PSE) evaluation module and TI Design based on TI's new TPS23861 PoE controller. The high-performance quad-port controller and reference design significantly reduce development time and cost when creating PoE-enabled network video recorders, IP phone switches and wireless base stations.
Features and benefits of the PoE PSE design:
  • Reduces PoE development costs: The TPS23861 evaluation board features two controllers with associated circuitry on a two-layer printed-circuit board (PCB), minimizing material and build costs that often occur when using multiple boards.
  • Easy to use, "plug and play" operation: The evaluation module is also offered in auto mode, eliminating the need for host control.
  • IEEE-compliant: The TPS23861 passes the University of New Hampshire's Interoperability Lab and SIFO's test suites.
  • Thermal design flexibility: The TPS23861 consumption does not exceed 400 mW in any operating condition. The external FET architecture allows the design engineer to select the FET that best meets size, cost, and efficiency requirements.
  • Enhanced reliability:  The four-point detection feature avoids system damage by preventing erroneous start-up.
TPS23861EVM-612 evaluation module
TPS23861 Features:
  • IEEE 802.3at Quad Port PSE Controller
    • Auto Detect, Classification
    • Auto Turn-On and Disconnect
    • Efficient 255-mΩ Sense Resistor
  • Pin-Out Enables Two-Layer PCB
  • Kelvin Current Sensing
  • 4-Point Detection
  • Automatic Mode – As Shipped
    • No External Terminal Setting Required
    • No Initial I2C Communication Required
  • Semi-Automatic Mode – Set by I2C Command
    • Continuous Identification and Classification
    • Meets IEEE 400-ms TPON Specification
    • Fast-Port Shutdown Input
  • Optional I2C Control and Monitoring
  • TSSOP28 Package 9.8 mm × 6.6 mm
For custom power management programmability and configuration, the TI Design's motherboard provides interfaces for two optional boards, the MSP-EXP430G2 LaunchPad and USB-to-GPIO Interface Adapter, which are both available in the TI eStore.
Availability, packaging and pricing
Available now in a 28-pin TSSOP package, the TPS23861 PoE PSE controller is priced at US$3.40 each in 1,000-unit quantities. The TPS23861EVM-612 evaluation module is available for US$299 and includes a downloadable PI Commander graphical user interface. A fully tested and proven TIDA-00290 PoE reference design with schematic, bill of materials and design files is also available for download.
ti.com
