Controller Supports New Levels of Flexibility for High Current Designs
Intersil ISL78268
55 V ISL78268 Buck Controller Provides Very High Step-Down Efficiency for Industrial and Automotive Applications
Intersil Corporation announced the ISL78268 55 V synchronous buck controller with 3 A integrated high side and low side drivers. The most versatile high voltage buck solution available, the ISL78268 buck controller provides very high step-down efficiency for a wide variety of load currents from under 5 to over 25 A, enabling it to support virtually every 12, 24, or 48 volt high current buck requirement for automotive and industrial applications.
Intersil - ISL78268
For heavy load applications, designers often have to balance power conversion efficiency against size and noise constraints. This requires making trade-offs among component selection, switching frequency, and output ripple and often requires the power stage to be tailored to the load in question. The ISL78268 buck solution was designed specifically to be flexible so that it can be used regardless of the optimization balance.
The ISL78268 buck controller enables easy conversion from high primary rails (typically 12, 24 or 48 V) to lower secondary rails (typically 3.3, 5.0 or 12 V). It fully integrates both a peak current mode synchronous PWM controller and a dedicated constant current control loop as well as high-side and low-side FET drivers that have adaptive dead time control. The ISL78268 device's tolerance of 55 V inputs makes it ideal for automotive applications, including support for the 12 V clamped load-dump specifications and new 48 V power system being adopted by European OEMs. The integrated 3 A driver allows the ISL78268 buck controller to sharply switch small power FETs or parallel combinations of large FETs while minimizing dead time to reduce switching losses, improve efficiency and reduce excess heat dissipation. This allows a single buck controller to be used across a wide variety of load requirements, simplifying design and reducing time-to-market.
Features and Specifications:
  • Supports 5-25 A loads and can be used in a two-phase, current sharing configuration to support loads up to 50 A
  • 55 V input tolerance (60 V abs max)
  • Integrated 3 A FET drivers and PWM controller for cycle-by-cycle peak current limiting
  • Provides average current limiting to extend battery life in battery charging applications and avoid inductor current runaway in supercap charging applications
  • Adaptive dead-time control to prevent overlap current and minimize body diode conduction losses with varying sized power FETs
  • Selectable diode emulation and burst mode for light loads
  • Adjustable switching frequency from 50 kHz to 1.1 MHz
  • Low shutdown current of 1 µA
  • AEC-Q100 qualified
Availability
The ISL78268 is available now. Pricing for the ISL78268 buck controller starts at $2.45 USD in 1k quantities. The ISL78268 is offered in a 24 lead 4×4 mm QFN package. The ISL78268 is supported by the ISL78268EVAL1Z, evaluation kit available for $83.33 USD each.
The ISL78268EVAL1Z Evaluation Board
The ISL78268EVAL1Z Evaluation Board.
intersil.com
