Vishay Intertechnology Launches New High-Voltage Thin Film Resistor Divider Network in Compact, Surface-Mount 1206 Case Size
Vishay HVRD
Vishay Intertechnology introduced a new high-voltage thin film resistor divider network that offers a compact, higher-precision alternative to functionally equivalent products built on thick film technology.
Vishay HVRD
The new Vishay Dale Electro-Films HVRD features an absolute tolerance to 1%, ratio tolerance to 0.1%, absolute TCR as low as ± 50 ppm/°C, and TCR tracking of ±10 ppm/°C. Offered in a surface-mount 1206 format, the HVRD is compatible with high-speed assembly equipment, with edge castellation to allow visual inspection of solder joints.
Featuring a high 120 V maximum operating voltage, the HVRD will be used for voltage division in power converters, battery management circuitry, high-voltage test equipment, renewable energy and smart grid systems, and a wide range of industrial applications.
vishay.com
