Silicon Labs Introduces New Ultra-Low-Power Temperature Sensors
Silicon Labs Si7050 Si7053 Si7054 Si7055
High-Precision Si705x Sensor Family Offers Exceptional Accuracy Across Full Operating Temperature Range with Best-in-Class Power Efficiency
Silicon Labs introduced a new family of high-precision temperature sensors offering industry-leading power efficiency. Silicon Labs’ ultra-low-power Si705x temperature sensors consume only 195 nA (typical average current) when sampled once per second, which minimizes self-heating and enables multi-year coin cell battery operation. Unlike traditional digital temperature sensors, the Si705x devices maintain their accuracy across the full operating temperature and voltage ranges and offer four accuracy levels up to +/-0.3 °C. The sensors are ideal for HVAC, white goods, computer equipment, asset tracking, cold chain storage, industrial control and medical equipment. AEC-Q100-qualified versions are also available for automotive applications.
Silicon Labs - Si705x
Traditional approaches to temperature sensing that use thermistors or embedded MCU temperature sensors suffer from poor accuracy and higher power consumption. Although improved accuracy can be achieved through end-of-line calibration, this technique presents additional manufacturing costs and challenges while accuracy is still susceptible to variations in power supply voltage. In contrast, the Si705x sensors’ patented signal processing technology provides stable temperature accuracy over the entire operating voltage and temperature ranges without the need for costly end-of-line production calibration. In addition, the integrated low-power analog design delivers an optimal price/performance solution with up to 35 times better power efficiency than competing temperature sensor products.
Si705x Functional Block Diagram.
Available in a compact 3 mm × 3 mm DFN package, the Si705x sensors feature an industry-standard I2C interface for easy configuration. Each device provides up to 14-bit temperature resolution for high-precision measurement, and the -40 to +125 °C temperature range is suitable for consumer, industrial and automotive applications. With a low 1.9 V minimum power supply voltage, the Si705x sensors can be connected directly to a battery without the need for an external voltage regulator.
The Si705x temperature sensors are pin-compatible and software-compatible with Silicon Labs’ popular Si70xx RH and temperature sensor family. This compatibility enables existing RH sensor designs and software to be reused easily for temperature-only applications.
Pricing and Availability
Samples and production quantities of Silicon Labs’ Si705x temperature sensors are available now. Si705x sensor pricing in 10,000-unit quantities begins at $0.61 (USD). The Si705x USB dongle evaluation kits, priced at $49 (USD MSRP), streamline Si705x sensor evaluation and application development. The Si705x USB dongle kits are supported by a Windows-based GUI that simplifies control of the Si705x sensors and temperature measurements. A variety of source code and driver examples is available in Silicon Labs’ Simplicity Studio development environment.
Si705x USB Dongle Evaluation Kit
Si705x USB Dongle Evaluation Kit.
Si705x Digital I2C Temperature Sensors
Part Number
Temp. Accuracy
Package Size
Typ
Max
Si7050
Digital I2C
temperature sensor
±0.5 °C
±1.0 °C
3 × 3 mm
Si7053
±0.2 °C
±0.3 °C
Si7054
±0.3 °C
±0.4 °C
Si7055
±0.4 °C
±0.5 °C
