NVE Introduces 5 kV Two-Channel Isolators
NVE IL711VE IL721VE
Best-in-class high-voltage performance of 5000 volts isolation and 1000 working volts
NVE Corporation announced the introduction of the two-channel IsoLoop IL711VE / IL721VE Isolators with best-in-class high-voltage performance.
NVE - IL711VE, IL721VE
The two-channel parts are available either with one channel each direction or both channels the same direction.
NVE - IL711, IL721
V-Series Isolator specifications include:
  • 5 kVrms isolation (1 minute) per UL 1577
  • 1000 Working Voltage (line voltage) per VDE 0884-10
  • Data Rate 110 Mbps
  • Up to 125 degrees Celsius operating temperature
  • More than 100 teraohm barrier resistance
A Unique Barrier
Isolation is provided by NVE’s unique ceramic/polymer composite isolation barrier with a barrier resistance of 100 teraohms and an extrapolated life of 44000 years.
True 8 millimeter Creepage
The new isolators use NVE’s True 8™ isolator package, which meets demanding eight millimeter creepage requirements under IEC 60601. With ordinary wide-body packages, full eight millimeter creepage cannot be assured.
NVE - IL711, IL721
Rigorous Testing
V-Series Isolators are 100% tested to 6000 Vrms (8486 Vpeak), and to a best-in-class 1000 Vrms Working Voltage per VDE 0884-10.
Popular Applications
The new parts are ideal for demanding applications such as medical instruments, smart-grid interfaces, motor drives, and power supplies.
Available Now
The new IL711VE and IL721VE are in stock for immediate delivery, along with many other 5 kV isolators, including four-channel isolators and isolated transceivers.
