Microsemi and STMicroelectronics Collaborate to Develop World-class IoT Solution for Innovative Home-automation Solution
Microsemi ST2100 Le87501
Microsemi Corporation announced its collaboration with STMicroelectronics on a new electric vehicle car charger solution using Microsemi's innovative PLC line driver. This is the first of several solutions targeting systems architects and designers who develop solutions for the Internet of Things (IoT). The initial collaboration, the module for electric vehicle supply equipment (MEVSE) featuring vehicle-to-grid (V2G) communication and support for a wide range of network and application protocols from Tatung, utilizes the Microsemi Le87501 PLC line driver and the ST2100 STreamPlug SoC from ST, along with a new proprietary state Machine, event-driven- (SMED) based digital power controller and is supported by the OpenV2G software stack.
Microsemi ST2100
The Microsemi Le87501 PLC drivers are based on Microsemi's proprietary high-speed, high-voltage bipolar process technology, which enables significant performance and cost savings over currently used technologies. Microsemi's industry-leading devices have also been selected by ST for reference designs for its recently announced ST2100 STreamPlug SoC products used in applications where high integration levels and computation performance are required, such as consumer home area networks (HANs), industrial and smart-grid applications.
This is the first collaboration between ST and Microsemi targeting IoT. According to IDC, IoT technology and services spending will generate global revenues of $8.9 trillion by 2020, growing at a compound annual rate (CAGR) of 7.9 percent. Microsemi and ST are enabling additional capabilities with the use of the Microsemi Timberwolf audio processors for command and control as well as audio sensing. The Timberwolf DSP platform enables Microsemi to leverage its extensive expertise and leadership in voice communications to bridge into new and emerging hands-free applications that require clear speech, free of noise and echo.
The world's first intelligent-gateway SoC, ST's ST2100 STreamPlug combines a high-performance processing subsystem with power line communication (PLC), security and peripheral features to support hybrid networks utilizing popular wired and wireless standards, including HomePlug® AV and HomePlug Green PHY. The STreamPlug SoC also integrates a PLC modem and analog front end.
These solutions will be shown at the Microsemi suite and in ST's private suite in Las Vegas during the 2015 CES, Jan. 6-8, 2015 in the Embassy Suites Executive Boardroom, located at 3600 Paradise Road in Las Vegas.
About the Le87501 Line Driver
The Le87501 is a single channel line driver designed to work in HomePlug Alliance HPAV2 systems. When enabled, the operation can be set to full, 90 percent or 80 percent power. The Le87501 delivers superior performance and can drive a line impedance of 100ohms down to 12ohms through a proper transformer. In addition, the Le87501 features a standby state which forces the driver into a long-term sleep mode.
Features:
  • Small 16-pin, 4×4 mm QFN Package
  • Low Power Operation
  • Class AB Operation
  • Enable/Disable Control
  • Capable of Driving Line Impedance Between 12 ohms to 100 ohms
  • Operation to 86 MHz
  • RoHS-compliant
About the STMicroelectronics STreamPlug ST2100
The STreamPlug ST2100 device is ST's broadband PLC solution, based on the powerful ARM926EJ-S™ processor (up to 333 MHz), widely used in applications where high computation performance is required, such as consumer HAN, industrial and smart grid applications.
In addition, the STreamPlug ST2100 has a memory management unit (MMU) that allows virtual memory management—making the system compliant with the Linux® operating system. It also offers 16 Kbyte of data cache, 32 Kbyte of instruction cache, JTAG and ETM™ (Embedded Trace Macrocell™) for debug operations.
