Silego Technology's 2.0 mm x 3.0 mm 18-GPIO SLG46620V GreenPAK4 strengthens analog features and accuracy
Silego SLG46620V
Silego Technology announces the fourth generation of GreenPAK (GPAK) Mixed-signal Matrix ICs. The GPAK4 family strengthens Silego’s industry leading position in Configurable Mixed-signal ICs (CMIC).
Silego - GreenPAK4
Silego’s GPAK4 family of NVM Programmable CMIC devices enables innovative designers to integrate many system functions such as comparators, ADCs, logic, delays, counters, resets, power sequencing, voltage sensing, and interface circuits while minimizing component count, board space, and power consumption.
The SLG46620V is the first member of the 4th generation of GPAK products comprising the best analog and digital resources from previous generations with expanded functionality and improved accuracy. The SLG46620V has nearly double the on-chip resources when compared to previous generation parts. This new device also includes new functions, such as a hardware reset pin and a DAC. The chip is available in a tiny 2.0 × 3.0 × 0.55 mm 20-pin STQFN.
Complete schematic in GreenPAK4 Designer
Complete schematic in GreenPAK4 Designer.
Like other devices in the GPAK family, development of SLG46620V projects takes advantage of the easy-to-use GPAK development hardware and simple GUI interface of GPAK Designer, allowing engineers to quickly and easily implement new designs and respond to changing design requirements.
GreenPAK4 Development Kit.
Target Applications include:
  • Consumer Electronics:
    • Portable: Tablets, Smartphones, Notebooks
    • PCs and PC peripherals
    • Wearable
  • Commercial and Industrial Electronics:
    • Servers
    • Embedded PCs
    • Data Communications Equipment
