Extra Small Crystal Offers Ultra Tight Stability
CTS Model 416
Perfect for High Density Applications
CTS Corporation announces the addition of the smallest quartz crystal member, Model 416, to its family of frequency control products. The device is housed in a 1.6 × 1.2 mm ceramic 4-pad surface mount package that is hermetically sealed, providing excellent accuracy and long-term reliability. Its small form factor is the perfect fit for very tight space applications such as wearable electronics, microprocessors, Bluetooth, hand-held devices and other smaller end products.
CTS - Model 416
Model 416 features common frequencies 24 MHz, 26 MHz, 27 MHz, 30 MHz, 32 MHz, 36 MHz, 40 MHz, 44 MHz, 48 MHz and 52 MHz with additional frequencies from 24 – 80 MHz available or under development. It maintains excellent standard stability of ±20 ppm at operating temperatures of –40 °C to +85 °C and even tighter stability ±10 ppm available at other temperature ranges. The product is fully RoHS 6/6 compliant.
Production and samples of Model 416 are available now.
