New Vishay Intertechnology Series of Snap-in Power Aluminum Capacitors Offers Compact Case Sizes Down to 20 mm by 25 mm
Vishay 256 PMG-SI
Vishay Intertechnology introduced a new series of miniaturized snap-in power aluminum capacitors with high capacitance from 820 µF to 47,000 µF in compact cases down to 20 mm by 25 mm. Designed for audio, industrial, and general power supply applications, 256 PMG-SI capacitors offer a long useful life, high ripple current, and low ESR.
Vishay 256 PMG-SI
Featuring a cylindrical aluminum case with a pressure relief valve, insulated with a blue PET sleeve, the new Vishay BCcomponents snap-in capacitors released today are available in 17 case sizes ranging from 20 mm by 25 mm to 35 mm by 45 mm, with voltages from 16 V to 100 V. The devices offer a wide temperature range from -40 °C to +105 °C, useful life of 2000 hours at +105 °C, ripple current to 4.85 A, and ESR down to 14 mΩ.
Device Specification Table:
Case size (D × L in mm
20 × 25 to 35 × 45
Capacitance range
820 µF to 47,000 µF
Tolerance
± 20 %
Rated voltage
16 V to 100 V
Ripple current at 120 Hz and + 105 °C
1.14 A to 4.85 A
Category temperature range
-40 °C to +105 °C
Useful life at +105 °C
2,000 hours
Shelf life at 0 V and +105 °C
1,000 hours
Max. ESR at 120 Hz and +20 °C
14 mΩ to 332 mΩ
Sectional specification
IEC 60384-4/EN130300
Climatic category IEC 60068
40/105/56
As polarized aluminum electrolytic capacitors with a non-solid electrolyte, 256 PMG-SI series devices are ideally suited for smoothing, filtering, and energy storage in pulsed power applications for audio amplifiers, LED drivers, UPS systems, and solar power micro-inverters. The capacitors are lead (Pb)-free and RoHS-compliant.
