TDK Announces Ultra Compact Onboard Type AC-DC Power Supply KWS-A Series
TDK-Lambda KWS5A KWS10A KWS15A KWS25A
  • Ultimate convenience: All-in-one design eliminates the need for external components
  • Extremely small dimensions: 66% smaller footprint compared to existing product (KWS10)
TDK Corporation announces the successful development of the KWS-A series of ultra compact onboard type power supplies to be marketed under the TDK-Lambda brand. The lineup comprises four models rated for 5 W, 10 W, 15 W, and 25 W, to meet a wide range of customer needs. TDK-Lambda Corporation will start accepting orders for the new product from October, and shipping will begin in November 2015.
TDK-Lambda - KWS-A
The KWS-A series products are onboard type switching AC-DC power supplies developed for use mainly on control boards in a wide range of equipment. The series adopts an all-in-one design aimed at maximizing user convenience by making board design as easy as possible for the customer. There is no need to provide parts such as fuses or electrolytic capacitors externally.
The new product also contributes to significant space savings. Compared to the existing product (KWS10), a reduction in footprint requirements by as much as 66% has been achieved through drastic miniaturization. Requirements such as high efficiency and low standby power consumption are being met through improved efficiency which is 6% better than earlier model (KWS10-12 with 200 V AC input). No-load power consumption has been reduced to 0.5 watts or less. In addition, the products are rated for a wide operating temperature range (-10ºC to +85ºC, start up at -40ºC to -10ºC).
Main applications
  • Control boards in control and measuring equipment, NC machine tools, semiconductor manufacturing equipment, communication equipment, traffic supervision equipment etc.
Main features
  • Ultimate convenience: All-in-one design eliminates need for external components such as fuses and electrolytic capacitors
  • Extremely compact dimensions: 66% smaller footprint compared to existing product (KWS10)
  • High efficiency: 88% (KWS25A-24, with 200 V AC input)
  • No-load power consumption: 0.5 W or less
  • Wide operating temperature range: -10°C to +85°C
    (-10°C to +55°C, load factor 100% *start up at -40ºC to -10ºC)
Key data: KWS-A series
Model
KWS5A
Input Voltage Range
85 to 265 VAC / 120 to 370 VDC
Efficiency at 24V (200VAC typ.)
77%
84% 85% 88%
Nominal Output Voltage
5/12/15/24 VDC
Maximum Output Power
5 W
10 W 15 W 25 W
Operating Temperature
-10°C to +85°C (with output derating)
*Start up at -40ºC to -10ºC
No Load Power Consumption (typ.)
(with 200VAC input)
0.5 W Max
Safety UL60950-1, CSA60950-1, EN60950-1
EMI EN55011/EN55022-B, FCC-B, VCCI-B (Need External parts)
EN55011/EN55022-A, FCC-A, VCCI-A (No Need External parts)
Size (W × H × D mm) 25.4 × 21.5 × 38.1
(1˝ × 1.5˝)
25.4 × 24 × 50.8
(1˝ × 2˝)
25.4 × 29 × 63.5
(1˝ × 2.5˝)
Board Type Double-Sided Board
Warranty 3 years
