Pocket-sized USB/Ethernet Controlled True RMS Power Sensors, 50 to 6000 MHz
Mini-Circuits PWR-6RMS-RC
Mini-Circuits’ PWR-6RMS-RC USB/Ethernet power sensor turns your PC into a low-cost power meter. This model provides true RMS detection, allowing highly accurate measurements of CW, modulated, and multi-tone signals over frequencies from 50 to 6000 MHz with dynamic range from –35 to +20 dBm. It provides fast measurement speed of 30 ms, 0.01 dB measurement resolution, and low typical measurement uncertainty of ±0.05 dB.
Mini-Circuits - PWR-6RMS-RC
USB control and power connection provides an easy-to-use interface for signal monitoring and data acquisition from most desktops or laptops. Ethernet control supporting HTTP and Telnet protocols provides setup flexibility and easy remote test management. The power sensor is provided with Mini-Circuits’ user-friendly GUI control software, which gives you a full set of measurement tools including measurement averaging, time-scheduled measurements, and multi-sensor support (up to 24). The GUI also comes with a built-in library of measurement applications for RF testing of couplers, filters, amplifiers and many more. View data and plots on-screen, or export to Excel® for simple reporting and data analysis.
The PWR-6RMS-RC USB/Ethernet RMS power sensor is available off the shelf for $1595 each. Place your order online today for delivery as soon as tomorrow!
